eyeofthetiger
- Aug 28, 2004
I was going to go buy the bfg 6800 oc with farcry and doom3 at best buy deal tonight but should I wait for the 6600 gt? Will it outperform the 6800 nu and how much will it cost?
Xxplosiv said:100 $ more, and its def. worth it. save up and get the GT
BigTaf said:its my understanding the 6600 will be a slower card
however it does have SLI support
so perhaps instead of a 6800GT you can run dual 6600 in SLI
2 6600 GTs probably would be a similar load on the PSU as a single 6800 Ultra, given that the regular 6800 draws 45% less power than a 6800U.JiveMofo said:but that requires a mobo upgrade also, so no $$ savings there. and i wonder how much 2 6600's will tax a PS, will an upgrade be needed there?
Mojo said:6800nu will be better than a 6600GT
Think about it...
128mb ram each
6800 has 256bit ram, 6600gt has 128bit ram
6800 has 12 pipes, 6600gt has 8 pipes
The only thing the 6600gt has going for it is higher clocks. Which is something pretty good I guess. But there's no way it will be better than a 6800nu, will it?
