GForce64 said:I just installed a 6800GS yesterday, ran NFS: MW great, popped 4800 3dMarks in 05. Run MW today, it's slow as heck, so I run 3dMark again. 1700. What the heck could happen to my card in such a short period of time to make it so slow?
Merc said:The culprit is something other than your video card. Check CPU temps. You are running a "hot" video card that dumps its waste heat into the case. This raises the case air that your CPU's HSF is using to cool the CPU which makes the CPU run hotter, which raises the case temp further, etc. etc. All of a sudden your CPU is throttling back to save itself.
A simple solution may be to purchase an Arctic Cooling GPU cooler which cools your video card better, and quieter, than OEM while dumping the waste heat out the back of the case rather than into it, thus relieving the stress on all the other components, including your CPU.
So , record the CPU temps and if they are higher then use the above $35 solution to get back to equilibrium.
Kil4Thril said:Do you have thermal throttling for your CPU turned on?
54YW4T said:i say its PSU.....
GForce64 said:That would seriously suck, considering it's a 500w Antec.
Edit: This has the makings of a cooling issue. Just take case panel off, 2789.
Bona Fide said:If it was a cooling issue, taking the side panel off would alleviate 99% of the problems. There's something else wrong here. My guess is bad contact with the heatsink on the GPU, or bad thermal paste.
