ChingChang
- Mar 27, 2003
EDIT: actually this is a 7800GT... also sorry if host is being slow!
built a computer for a friend about a year ago. He is now having overheating problems with his video card. Temps were around 90C under load. I find a ton of dust inside the heatsink, clean that, regrease GPU, and temps go down to about 80C.
Couple months later he says he's getting more artifacts in Counter Strike and WoW. I check out the video card... heatsink feels way too hot to the touch, and it's at 85C under load. Heat transfer is great, so I just check to clean out dust (wasn't much)
My solution was to attach a $1 80mm case fan with zip ties and copper wire...
(two more pics here)
Well I tested again, and I think it was only down to about 80C after putting that fan on.. seemed like fan was obstructing the flow of air or something.
So I prop it up with paper clips:
And stabilize with copper wire and zip tie:
Saved the cover and screws just in case
and doesn't look bad installed in computer:
more pics here (sorry if host is being slow)
results before:
idle ~ 70C
load ~ 85C
after:
idle ~ 60C
load ~ 70C
and the guy just brought it back to his house, guess his room is a lot colder cause he says it's saying 45C idle!
not bad for a $1 mod huh...
results before:
idle ~ 70C
load ~ 85C
after:
idle ~ 60C
load ~ 70C
