So far, my first ATI purchase in nearly 10 years is failing to impress me. However, if I can somehow manage to fix these 2 problems outside of replacing the card, I'll be a happy camper. If I'm forced to RMA it, I'll honestly never buy another ATI card in my life. Maybe I just have bad luck with them. Anyways, these are the two problems I am having:
1. The second I open a game, the card starts emitting an annoying buzzing noise (it is not the fan). The second I close said game, it instantly stops. It's not super loud or anything, but even though the fan is at 45% and the case is 4 feet away I can still hear it.
2. Incredibly random black screen flashes. The screen will flash black for about 1 second then return. For the life of me I cannot reproduce this problem at will, it seems to be completely random. It doesn't happen that often, and it can happen at any time (browsing the web, gaming, browsing through system folders). Some days it doesn't happen at all, some days it happens 3 or 4 times. Sometimes it has happened 2 times in a row within 5 seconds of eachother. This one just has me baffled. It *seems* to happen most often when I am browsing the web or going through system folders.
I can bring myself to live with the buzzing noise if I have to, but the black flashes I"m not so sure about. Both of these problems existed before and after I unlocked it to a 6970, so it has nothing to do with that. Also, since someone will probably mention it, my temps are fine. My room is very cool, and I keep the fan at a fixed 40% speed. It idles around 32-38c depending on my room temp, and it never exceeds 65-70 while gaming.
edit: Sorry, I meant to post this in the
