In the nvidia control panel there is an option to overclock my vid crd. My secondary card will overclock fine. But it will not allow me to overclock my primary card. Even if I set the speeds to below stock. It will tell me that the tests failed. I've also tried riva tuner with the same results. Is there something else I should be doing or is my primary card just not overclockable?
Also when I enable SLI. It will do the same thing behaving as one card. I twill not allow me to overclock the card. And again even at below stock it tells me the tests failed and will not allow me to set the oc option.
Funny thing is that the stock speed reads as 450core 1200mem. But when running 3dmark. The speeds are read as 491 core 1197mem. Which of the two speeds is my SLI running at? And is that the reason why I cannot oc?
