Here's my latest mod - I used an EVGA ACS copper cooler and fan from one of my 7800GTX 256 cards on a 7900GTX 512 so that I could fit two 7900GTX 512's and a Creative Audigy2 ZS in my SG01 NOTE: I did have to dremel 1-2mm from a small section of the ACS cover next to the fan plug as it was making contact with some of the components on the PCB of the 7900GTX 512
This definitely answers the question whether a single slot cooler will work on a 7900GTX 512
After running some benchmarks and games the temps on my outside card with the single slot cooler are only a few degrees higher at idle / load than my inside card that has the stock double slot cooler!
