Chaos_Being
- Oct 26, 2005
Well, looks like I just ran into a MAJOR stumbling block with my new build.
First of all, a quick rundown of my components- Opty 165, MSI K8N Diamond Plus, 2gb G.Skill pc4000, Silverstone Zeus 560w, and finally, an XFX Geforce 7900gtx factory overclocked to 665mhz core (from 650,) and 1.63ghz memory (from 1.6ghz.) Everything else is still at stock speeds.
I played an evening of WoW on it last night just fine. Today I decided to run 3Dmark 06 and a few other benchmarks at stock to get a baseline of comparison for when I start overclocking. All of the tests completed successfully until I got to "Deep Freeze." The first time, it locked up around frame 1400, bluescreened, and rebooted. I found this error message in the event viewer:
"The driver nv4_disp for the display device \Device\Video0 got stuck in an infinite loop. This usually indicates a problem with the device itself or with the device driver programming the hardware incorrectly. Please check with your hardware device vendor for any driver updates."
I was running the newest certified driver at the time. So, I went to Nvidia.com and downloaded the latest beta driver, ran driver cleaner in safe mode, rebooted, and installed the beta drivers. I ran 3Dmark 06 again and it locked up again on the same test, at about the same time- except this time, instead of bluescreening after it locked, the screen started flashing an artifacted combo of the 3D mark screen and my desktop.
Oh, and the molex connector on the motherboard that helps to power the video cards is plugged in.
Are there any other drivers that I can try, or ANYTHING else I can try before I have to consider an RMA? The only other thing I can think of is to try downclocking it to stock speeds and try the test again, as I know from reading that I'm not the only person with a messed up factory overclocked 7900 series card
