bubomatic5
- Sep 4, 2007
I just overclocked my BFG 7950 GT and get temps of idle 57 C and Load 82. Are those safe?
Safe? I think the GPU limit tends to be higher than CPU...
70c is the highest I'd let my CPU go, 100c for GPU
I think you'd be O.K.
Any artifacts?
That should be fine. I have a bfg 7950 GT 512 and iirc I get slightly better temps (75ish load) but 82 as a max is fine. 90c is where I start to worry on graphics.
