Are there any good OC tutorials on the 8350 that make reference to the FSB/NB? So far all I see is adjusting the multiplier and voltage. I have been messing with my chip for a bit and it looks like the sweet spot is 4.5ghz. Currently I have ran 1.36v (CPUZ) for 12 hours on Prime95.
What I'm going to do is see how low I can get the voltage on 4.5ghz and then see what voltage I can get for 4.6ghz+. My understanding of overclocking the 8350 is to use the multiplier and voltage to get the general clock and then messing with FSB/NB/RAM to fine tune but I can't find any good tutorials describing the relationship so I'm not sure how to fine tune it.
I'm using 4.5ghz as my worst case scenario overclock. I can do about 1.42v on prime95 until my temps are too high. In my real world use I don't get close to maxing it so technically if I could Prime95 it at ~1.42v I would be at my max temp but I wouldn't get close to it in real world use so I'm not worried. For the time being I'm using a window fan to pump cold air in to my room. I've had the room down to 45f which is great for OCing. Once it's summer I will run the 8350 at the voltage safely but it will not run prime95 since the ambient is too high. Since I will never hit the max temp in real world I would like to use the winter air to stress test it and confirm it's stable and then once summer comes around I won't have to worry about heat due to low stress.
