I have an MSI GeForce 8400GS (PCI-E 2.0 x16) that runs a little on the hot side for my tastes. I'd like to remove the stock HS and replace it w/ something more efficient. It seems like a number of people are recommending the Zalman series of product, particularly the ZF-700 or ZF-900. I only paid $25 for the card, so I can't justify a $35 HS (the ZF-900) so I'm thinking pretty hard about the VF-700.
1) Is there anyone here using this cooler on this card? The Zalman website page for the ZF-700 doesn't show the 8400GS as a compatible card, but then again, it doesn't look like it's been updated in a while either.
2) Do you have this card and are you cooling it w/ something else that's doing a good job? What is it (manufacture/part) so I can check it out.
Thanks all!
Thanks all!
