Reworking some of my systems around and want to put the HTPC in my sig into the living room. Problem is that its an older SDTV with only Svideo in. I need a low profile card to fit into the case and it looks like the 8400gs is what would fit the bill. Will it be good enough for dvd play back, possibly blue-ray disks even though the low quality tv. (going to be ripping all my disks to hard drive and play them over the network with SageTV).
Also if anyone knows, considering using my Logitech x-540's in the living room with this system so i can leave my receiver in my bedroom. Problem is the only audio out is 3 port (line in/out, mic) and coaxial S/PDIF. It has the ability for ac97 or hd audio via internal headers. Anyone know of a place that i can just buy the header to 3.5mm ports to use with the x-540's.
