TwiceSliced
- May 1, 2002
After upgrading to Vista and removing my Audigy 2 ZS as the default audio device from the first system in my signature below, I made the FireWire Solo the new default device. Afterwards, I noticed that Pro Tools M-Powered 7.4cs2 would knock the sampling rate down to 44.1kHz, despite me setting it manually to 96kHz in the M-Audio control panel beforehand.
Some research revealed that Windows Vista controls the default audio device's bit rate and sampling rate, with 24/44.1 apparently being the highest supported by the operating system...
Does anyone have any ideas or experience that might help me figure out a workaround, or should I just put in another sound card and make it the default when I'm using Pro Tools?
Thanks!
Thanks!
