turtletrax
- Dec 31, 2005
Just put my rig together usung a 975XBX , Intel E6400 , OCZ PC2-8000 2x1G and having a strange problem. I can boot into the recovery mode of the BIOS but as soon as I try to go into the normal mode, my 120MM LED exaust fan just flickers and the machine will not boot.
It will initialize my LCD and then go into the RAID BIOS , then it will go black and hang, and after while if I push any keys on my KB it will beep.
Any ideas?
I was hoping to get away from the never ending RMA cycle that I feel I have been on for the past couple of months by going pure Intel but no luck...
EDIT: Problems solved.
Looks like it is my LCD not initializing after post. if I reboot the panel after post it is all good.
Look forward to Conroe OC
Any ideas?
