thinkdiesel
- Aug 24, 2007
The link has been removed, no one knows where to get that PDF?
http://www.mediafire.com/?khj21yzxmm2
anxiously awaiting my PA241W, that's lost in UPS land ugh..
hi,
got my PA241W for some weeks now and got some problems:
1. backlight bleeding (some say this is normal?!)
2. I got problems with text on that monitor. my old TN seems much sharper/ to have more contrast. I even sometimes get headaches when sitting too long in front of the NEC...
Anybody here who has made similar experience?
hi,
@supersnake: thanks for your help. the lower resolution is worse on my NEC and I spent "hours" with clear type configuration but I'm still not happy with it..seems that I have to live with it.... can't recommend that PA to anybody who uses the monitor not only for photo/ graphics editing.
Do you think I should try to contact NEC for an exchange -which probably will not make the thing better ;-) ??
You can use SpectraView II with all PA models but keep in mind that NEC doesn't implement corrections regarding the WCG-CCFL spectrum of most PA screens. You'll need the OEM EOD2 from NEC or a spectrophotometer (EyeOne Pro). If you live in Europe you could also use the Quato Silver Haze Pro bundle. iColor Display > 3.6 has generic corrections that work fine with the bundled X-Rite DTP94. Because of the extensive electronic and OSD and very good factory calibration a software calibration virtually is a hardware calibration in this case.So if I skip the Spectraviews is it enough to get a separate colorimeter to have the same hardware calibration capabilities as in the US model? I'm quite confused on that.
Because of the different (and regarding the mentioned effect disadvantageous) spectra you will experience effects of observer metamerism. You'll have to calibrate to a visual but not colorimetric identical whitepoint.What could I expect from having side by side different screens with different input lag and color spaces?
Denis, how would you compare the PA301w vs the 3090 in terms of picture quality (not inputs, helpers etc)?
Hi Mastaba,
Hi Mastaba,
- I've had 3 of these at my desk for months and I've heard no noise coming from the display and the heat isn't that bad. I run mine in portrait mode.
I hope that this helps!
-- Art
I have some complaints, though, and my biggest one is that the monitor was shipped without a proper power chord - European power cords don't fit Swiss power plugs. I emailed NEC just today and they are checking whether I received a non-swiss unit, although the manual doesn't have any reference to swiss standard (it has indeed reference to other countries' standards).
sRGB is can be calibrated with SpectraViewII software or via the internal calibration functionality, though it does only support i1 Display2 sensors at this time.
That's not really too unusual. I'm guessing it's just a normal iec320 (ie. kettle lead)? A lot of things you buy here tend to come with either European or UK plugs on them. From retailers like Digitec for example, they always bundle in an extra cord with a swiss plug, or adapter though.
Maybe I'm odd for having UK, Swiss and Japanese power strips near my desk though. I'm sure NEC will send you a Swiss iec320 if you ask them, they seem to have excellent customer services from what I've seen.
Hi guys,
I've had a PA 301w for about two weeks now. I'm really happy with it. I chose it over any offering from Apple because of the quality and the ergonomics. I wanted a matte screen and Apple no longer offers that. There is also the issue of not being able to adjust the height on the 27" display.
The colours on this monitor are beautiful and vibrant and it is equally at home doing either serious work or watching movies. If you're sitting on the fence regarding this one, I would recommend it.
No one will believe you until you post pics.
Yeah, I'm afraid its being driven by an 11" Macbook Air until the new Pro gets announced.
Don't laugh...
Hi all. First post in the forum. I just purchased the PA301W-BK-R directly from NEC. I currently own the LCD2690WUXI2 with the SpectraView kit. I assume I can use the same kit on the PA301 since in pictures the kit looks the same as the one that would have come with the PA301W-BK-SV?
Sorry for bumping a slightly older thread, but I didn't think this question deserved a new one.
I've just gotten a PA241W. Very happy with it, but I do have one issue -- I'm getting some colour banding in gradients. I use a smooth gradient on the Windows desktop and can notice some banding on it. I have since checked a greyscale gradient and also see banding on that.
The banding is not the kind that I usually see on low quality displays. On the greyscale, it's small, clearly distinguishable bands of the same width consistently throughout the gradient. It's like the banding you would see if you set Windows to 16-bit colour, except that the bands are significantly smaller in width.
I just want to check whether this is normal. I see similar bands on my lower quality Dell IPS displays and my laptop display, but I'm not sure if it's normal on the NEC. I am just using consumer video cards so I don't have 10-bit support, but I understand that wouldn't make a difference on the desktop or in internet browsers anyway. If it matters, I've tested on an AMD 6950 and Mobility 5650 with the latest drivers. Everything is set to native resolution and 32-bit colour. The monitor has been calibrated using Spectraview II and the banding is evident in all picture modes (including when calibrated to emulate sRGB).
Best regards
Denis
Yes.So, can i buy a Multisynch PA301W and a separate Spectraview kit (like this one ?) and make the exact same hardware calibration like with the "genuine" Spectraview bundle ?
The probe in the new SV bundle (i1 Display Pro) is very good. You should use it. An alternative would be to buy the i1 Display Pro (non OEM) separately and then SV II without probe to be more flexible regarding other software.Is it better than using another probe ?
