Hi is there a program to change the GPU voltage through a program (much like how R.Tuner changes clock speeds through o'clocking). I dont want to flash video card thruogh the BIOS and was hoping if someone had an idea?
laugh.... sorry bud all that stuff is controlled by standard resistors.. not variable resistors, if so major adjustment mite be possible.
The Only way to Up the Volts on you Card is the Volt Mod it... You may be able to soft mod it .1 of the volt but any major jump will have to be done Via Hardware Modification.
