I thought didn't have any issues with Windows A3 WUs and my nVidia GPU clients, but I was dead wrong. The new SMP2 client is not working properly in conjunction with my GPU clients. The A3 WUs just stall mid way through. This has affected two of my systems and they are very different hardware-wise (Opteron/Xeon). The only thing in common between these systems is Win XP. There is no effect if I shut down the process manager. The SMP client will only resume if I shut down the GPU clients, and they all need to be shut down. Something is in conflict when both clients run.
Out of curiosity, I started a Linux VM with the new SMP client and it works fine, quite a lot slower, but at least it works with the GPU clients. I guess being in its own environment is shielding it. For now, I'm forced to continue using a Linux VM until this problem is resolved. Has anyone else seen a conflict between clients with the new A3 WUs? At first I believed everything was fine, but when returning to my computer after several hours, the WU did not make any progress whatsoever despite FahSpy still reporting the same PPD (if a client stalls this monitor won't inform the user).
