gamer1drew
- Jul 17, 2004
Hi, Im been reading on how to OC the AMD 64 and want to clarify a few things. If I have a Clawhammer 3200+ and want to OC 10% from 2GHz to 2.2 GHz I should up the HTT to 220 Mhz which will mutiply by the clock multiplier of the default 10 to 2.2 Ghz. I should also lower the LDT to 3 which will give me an effective 220 x 3 = 660 Mhz HT effective Rate. For Ram I should get low Cas 3200 instead of high Cas High Frequency and and use the HTT to Ram Frequency of 200 to 183 leaving my Ram running at 220 *(200/183) = 201.3 Hhz.
Questions
I will be using a MSI K8N Neo Platinum with the NForce3 250 GB. Will this allow me to leave the LDT multiplier at 4 so effective HTT will be 4 * 220 for 880 Mhz. Also is the limitation for the NForce3 250 GB 800 or 1000? All the socket 754 mobos claim 800 but online tuts claim 1000 Mhz. How much does the effective HTT matter in relation to performance?
What are the benefits of changing the CPU multiplier besides getting closer to the Max HTT effective Rate or Max Ram Frequency?
Ex.
HTT efective rate max is 1000(Im not sure that it is as I stated above just say it is) you overclock the HTT to 220 and with a 4 LDT you get only 880 Mhz. You want near 1000 so you up the HTT to 245 change the clock multi to 9 =2205 Mhz for the CPU and 245 x 4 LDT for 980 Mhz effective HTT which is closer.
How much does increasing the Ram Frequencies help? From what Ive read lower frequency with low Cas is better than High Frequency with High Cas. If this is true, Im going with Cas 2 PC3200 and using a HT to Ram Multiplier. On this note what are the HTT to Ram Multipliers Ive seen 200/200, 200/166, 200/133, andd 200/100. I also seen some use 200/183 and 200/166. If I dont OC the Ram I shouldnt need to up the vdimm right?
Also will I have to change the voltage settings if I only go form 2 GHz to 2.2 Ghz, and how will I be able to tell if they need upping?
Is this OC (10% from 2 to 2.2 )even possible on a clawhammer with the crappier revision (AP I think) and air cooled with the Venus 12?
Thanks for any help, sorry if this was confusing. Any terms I missused please set me straight.
Questions
Ex.
