dont know if you fixed your proiblem. but to test if its your memory that grapping out on you @ 260 then lower your CPU mult 2 ticks. this will take your CPU out of the equation. then run memtest86.psupef2k said:What stepping opteron do you have? I currently have this board, an opteron 170 at 2.6ghz, with Vcore 1.5v, 2GBHZ G.SKILL memory and prime is failing on core 0 in < 2 minutes.
I had it 2+ hours prime stable at this voltage at 2.5ghz, but when I upped the HTT to 260 (x10 multiplier), it is not stable at all.
Cooling is SI-120 w/ 120mm delta fan, and temps are idle ~32C-33C, load before prime fails is 43-44C, so that seems fine...I just can't figure out why it's failing so quick at 2.6ghz. Any thoughts?
