I've looked around some but can't find any information on the A8V's IDE ports. Does anyone know if they are locked? I've been hitting a wall w/ my a8v/3000+ .90nm and i'm thinking it may be the IDE controller. I am using the Promise controller for my 2 SATA drives. I have an extra PCI SATA controller and PCI IDE controller here that i can use if needed, but i don't want to add another PCI card to my box if the onboard IDE is locked and not holding me back. Any input would be helpful.
Also, anyone know if the 1009 final bios is stable? I'm on 1007 and have been waiting a bit on 1009 to hear the general concensus as 1007 has been working at least (heard bad things about 1008 and weirdness about 1009 beta's).
Has anyone replaced the stock cooling on the a8v's chipset (mine's just a heatsink, no active fan at all!)? I am wondering how hot that thing is getting at 80mhz+ over it's stock FSB rating and am thinking perhaps i could push the FSB higher with an active solution on it. I've already got one here, but i don't want to remove the stock if it's unnecessary...\
Thanks for any input you guys have.
