vladthedecker
- Feb 26, 2006
I just recently switched from an Epox 9npa+SLI to the AT8 32X because I'm contemplating going with a Crossfire system. Well on the 9NPA+ I could hit an HTT of 277 with a 9x multiplier (2493 mHz) at ~1.45V (the default voltage setting on the mobo) but on the AT8 I can't get the same speeds. I can only get the HTT to about 271. I can hit that at 1.425V but if I raise my voltage even as high as 1.6V I can't get a single additional mHz. However if I decrease the multipier to 8.5 I can get as high as 295 HTT. This is actually a higher clock than I can hit at 9x multi ( 2439 vs. 2507).
I don't understand what is going on here. It seems that I should be able to get a better clock at the 9x multi.I would think that I should be able to hit the same clock that I had in my Epox board (277*9) but it seems that overclocking with the default multi is not working on this mobo. Like I said before I can't get a single additional mHz by bumping the voltage from 1.425 to 1.6. That just doesn't seem like it should happen. I tried upping the northbridge voltage by 0.1V but that just made the whole thing wonky and I had to reset the CMOS.
Anyone have experience with this board or any suggestions?
Edit:
On the Epox board I could get my clock as high as 2.6 If I cranked the voltage up to about 1.55. I'm obviously not coming close to this on the Abit board.
Edit:
