Spankbot-5000
- Feb 12, 2006
Now that my Nvidia 8800 GTX bit the dust, I'm switching back to ATI. I'm going with an HD 4870 and an Accelero S1. I had a quick question about the ramsinks included with the Accelero though. I've read all the stories about the ramsinks falling off the card because they aren't particularly sticky, so I'm buying a few pieces of Akasa thermal tape. Should I clean off the pad/compound from the Accelero ramsinks so it's just the Akasa tape between them and the card, or should I leave the pad/compound on so it goes ramsink-pad-akasa tape-card?
