JayteeBates
[H]ard|Poof
- Jul 21, 2007
Looks like the egg is out of stock for a few days. ETA for resupply 3/8/2010
For FPS and Racing games 120hz is KING. That is all.
Seems, according to Tom, Alienware overall better :/
don't know, all I read from that was the Acer has better 'dark contrast', buttons with tactile-feedback, and is $100 cheaper.
I'm probably waiting for the two others to come out since I've made it this far without pulling the trigger. I still don't like that bezel, that's probably it. I need me a fast TN for my games but I love my 20" IPS.
Anyone check this out;
http://www.tomsguide.com/us/3D-Monitor-Acer-Alienware,review-1506.html
Theres something fishy about that site. No actual test methods or results, just 1-to-10 scale scores. How they can score response time without testing response time is beyond me.
Anyone done an input lag test vs CRT?
Hi there.
This is my first post in here after reading the whole thread.
I have my brand new GD245 for 3 days now, and i'm quite impressed with its performance, but i'm having an issue that's driving me crazy.
I have an i7 with an ATI 5850, and come from a 28" HannsG, and mainly i use the PC for FPS gaming.
On games, the monitor runs smooth and fast, no ghosting at all (tried MW2, BFBC2 beta, and Bioshock2), barely no bleeding... everything OK.
My problem comes in windows (W7) desktop. Fonts and characters appear like defocused, they have like a shadow between characters, and this is killing my eyes.
I saw a similar issue on another LCD time ago and the problem was with the HDMI cable, so i tried with the Dual link DVI, single link, HDMI, connected the laptop to the monitor, and all with the same results (on every frecuency range between 60-120Hz). I have re-installed drivers, and tried another SO, even downloaded the LCD driver from Acer web... no love. And if i connect my old LCD, everything shows Ok.
I'm not sure now, but maybe the 1st day i tried the monitor didnt had the issue, but after all this hell of tests, i cant assure it. Has anyone installed the monitor driver? It isnt digitally signed, and i dont know if that was the begining of all this shit.
Oh, i have also tried all that ClearType stuff that comes with W7 with no results.
I have done some photos, but they can't show the issue clearly. Anyway i'll upload them later, i'm at work now.
I don't know what else to do before sending the Monitor back for change, and that's the last option, since there isn't stock of it. And a little voice in my head tells me that this is something stupid and not a monitor issue...
Thanks.
I believe there was a bug with 2D/120hz + ATi but it was resolved in the cat 10.2's. If you haven't upgraded, that may be the place I'd start.
Here is a pic of the monitor, and on the bottom, my laptop to compare. Easier to see in full size.
http://img684.imageshack.us/img684/9919/sany0002h.jpg
And here a closer approach.
http://img130.imageshack.us/img130/5650/sany0003e.jpg
PD: i have run Bioshock2 in window mode and not only doesnt work on desktop, the game fonts appear to distort also
I'm fucking sick with this shit.
Hi there.
Thanks.
JonDo[H];1035372206 said:It looks like edge enhancement/sharpening.
This monitor has it in spades, and so far, even though I've found the service menu, it is completely non-adjustable. This shows up especially with the color fringing with cleartype fonts, and a white fringe (without cleartype) that shows up on fonts that are black on grey, such as menu text. Otherwise it's not a bad screen and the 120hz does work as advertised with my 5870.
That's one of only two dislikes I have with the screen: The over aggressive sharpening, and the lack of a direct input change button. Most other monitors in this class have a single, direct button that you can press to switch through the inputs. This one you have to enter the menu, and then hit the right most button to switch.
There is no ghosting, but there is still motion blur, albeit very low, and probably close to class-leading from what I see. Funny enough vertical movement/scrolling seems better resolved than horizontal movement. I might try and do some input lag testing with a VGA splitter and calibrate it with my Eye One Display 2 hardware and software and report back. Colors seem fine IMHO. Input lag also seems minimal, if there is any at all.
BTW, the panel is a CMO 120hz 23.5" panel. Going from memory it said CMO-M236-L02.
You can find this out by entering the service menu as such:
1) Turn off the screen
2) Hold down any of the control buttons at the bottom and turn on the monitor, while still holding the bottom "action" button. I used the one closest to the Power button.
3) Wait for the Acer logo to appear and then disappear and then let go of the button
4) Hit the middle button on the bottom (third from the right) and you should see a screen with Overdrive settings, and some other color settings
a press release said:Users can clearly view detailed images and crisp graphics due to the Acer GD235HZ display's 80,000:1 (ACM) contrast ratio. The Acer Adaptive Contrast Management (ACM) features advanced technology that allows users to adjust images frame by frame to optimize contrast by enhancing detail and gradation. Additionally, Acer ACM enables the new monitor to use less power and save energy while providing a superior viewing experience.
