Is there any real way to disable this on Sony Bravia televisions? When set to off it still runs.
I have found setting pixel format to YCbCr 4:4:4 in CCC and setting ACE to off reduces it kicking in considerably or bumping the brightness up a bit in CCC then lowering it a bit on the monitor helps too.
Just gets annoying when the lights go low in a tunnel in a game and the ACE makes the light at the end of the tunnel and the hud extremely dim. just to make the black look better.
