Oh, here is the setup. Our Lan has started to make a $5 donation per person mandantory to be eligable for door prizes. This should bring anywhere from $200-700/month for lan improvement.
Our current setup consists of a hodge podge of two Dell 2324 switches (24x 10/100, 2x 1000, unmanaged), Netgear 16 port gigabit (umanaged), and misc other switches(10/100, gigabit).
It is all served up using a custom linux setup that load balances the (four) connections(Cable Modems, DHCP) to the net over four cable modems(I'll explain how on Sunday, tonight/tomorrow is the trial by fire).
What I want to do is make the most use of the money we get in for lan improvement.
Here is the plan:
$1600 - 6x Dell 2724 (24 port Gigabit, webmanaged) - Phased in as needed
$400 - Linksys RV016 - Load balance up to seven connections (To replace the linux box that I'm hacking up for this, I want the setup to be simple in the future as I will only be with the LAN for another 6months or so.)
Do I even need to consider network segmentation when I'm looking at a lan that should never exceed 150 computers and is all gigabit? If so, what is the best(most cost effective) for doing the VLAN routing at gigabit. This is a gaming LAN, so all the computers need to talk to each other.
Keep in mind that as we phase in more switches, we spend around $300 on power cables to support that computer cluster. I figure the cost per seat is $20-25 between power and network. I chose the 2724 because it supports trunk aggregation on up to four ports, meaning a minimum of 2gigabit backbone if I daisy chain the switches.
Suggestions? Comments?
Things to keep in mind:
Whatever we don't spend on gear for the LAN will go to buy more prizes for the LAN. This is a completely non-profit venture. If we are regularly pulling in $500/month that just means we buy more equipment and game servers along with more prizes.
Here is the plan:
