Mostly web browsing. I will want to play Diablo 3 whenever that comes out though. I'm in IT, so I'll tinker with things, but I also have an ESX box at home for most of that.
The cheaper the better, but around $800
Dutchcess/Putnam/Westchester County of NY
Case, PSU, motherboard, CPU, RAM, video card, hard drive, DVD drive, 120mm fans and HSF
I have a 1TB drive from my old machine that I will be using for data
6) Will you be overclocking?
Not really my intent, might be nice to have the option though
7) 7) What is the max resolution of your monitor? What size is it?
1440x900. 19" wide screen. I will most likely be buying a new one though. Having two 24" at work is spoiling me.
Now, unless something awesome is coming out tomorrow and I should wait
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
None of those really. USB 3.0 might be nice for the future though
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes. Windows 7 64 bit
So here is what I spec'ed out so far:
LIAN LI Lancool PC-K7B
Antec NEO ECO 620C 620W PSU
ASRock Z68 PRO3
Intel Core i5-2500K
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Crucial M4 CT064M4SSD2 2.5" 64GB SSD
SAPPHIRE 100338L Radeon HD 6770 1GB
2x Scythe SY1225SL12L 120mm "Slipstream" Case Fan
and a random Samsung DVD burner
This all comes to a grand total of $805
Is there anything that's worth changing? Any comments? It almost seems like this might be a little over-built for my needs. Is there a HSF that anyone would recommend or would the stock one be ok? Like I said, I'm most likely not going to be overclocking like a nut if at all, so I don't need anything extreme.
ASRock Z68 PRO3
Intel Core i5-2500K
