My current system is my first A64 system and I understand that the FX55's run far hotter than the Athlon XP chips I'm used to. My current system with CnQ disabled runs at 40C idle and 55C load (after about an hour of gaming and 22.5C room temp). There are 2 6800U's in the box too so they obviously give off a lot. I have AS5 which still hasn't passed the 200 hour 'bed in' time, but do the temps sound okay? Not used to a processor running this warm...
At Idle with Cool N Quiet enabled the temp goes down to 31C.
I currently have a Lian-Li PC60 (2x80mm inlet, 2x80mm exhaust), stock cooling on the Ultras, and a TR XP120 HS with a YS-Tech 120mm 125CFm fan.
To start with I thought there was too much AS5 on there as I was getting temps in the 60's so I reinstalled it with far less on there and the temps went through the roof (the PC shut down at 75C!) I was using an Asaka 120mm Ultra quiet at the time too, which obviously wasn't enough. I then removed it again and redid the AS5 and upped the fan to the 125cfm YS-Tech jobbie and I got temps where I am now.
I'm wondering if the performance might be increased if I have the fan set to suck rather than blow. Since there is an exhaust fan mounted directly above it, AND Thermalright state that the XP120 can be used in either configuration....
