Hey all,
Just picked up a bunch of parts for a Sandy Bridge-E setup and had a couple questions regarding cooling.
I picked up a 3820 to go along with a Sabertooth x79 and hope to at least be able to OC to 4.5+, ideally 4.7 or 4.8. I'd like to pair this with a Noctua DH-14. Would this be a good combo or should I just go for a 212 EVO? The cost difference is not really an issue. I just want the best performance without resorting to watercooling. (Side note: I hope to upgrade to the hexacore Ivy Bridge-E chips when they come out if this makes any difference.)
Also, the case I chose is an Antec P280... I currently have a Antec P180 for my current build which I had to replace all the stock case fans a while ago. Ended up replacing them with Scythe S-Flexes. I'd like to replace the stock fans in the P280 as well up front so I don't have the hassle later and was wondering what are good case fans these days with the best performance to sound ratio? Since the P280 is a quiet case, I would like the replacement case fans to be quiet as well but still provide decent performance. Any suggestions? Or are the S-Flexes still good?
Anyone who actually has the P280 have any recommendations on fan placement to provide optimum cooling?
Finally, I've used Arctic Silver 5 for all my builds in the past... has any thermal paste come out recently that is better than AS5? Sorry, I am behind the times!
Thanks so much for your help!
