virtualrain
- Jul 31, 2005
I ran a simple experiment on my dual pump system, comparing delta-temperatures (air to CPU) at idle and load in four different configurations:
The chart below reveals some interesting facts...
Conclusions:
As expected, running both the fans and the pumps at full speed provides lower delta-T's than running them undervolted.
Also, not surprising, is the fact that increasing fan speeds (while keeping the pumps undervolted) provides a noticable increase in cooling performance... more airflow is definitely better than less.
The interesting revelation here, at least with my configuration, is that running the pumps at full speed without additional air flow only serves to dump more heat into the loop and actually performs WORSE!
My conclusion is that just increasing water flow without a proportionate increase in air flow, may actually hurt temperatures.
It's also interesting to note that you can actually gain a lot of peace and quiet by undervolting your fans and pumps at idle while still providing more than adequate cooling. Even at load, the undervolted components may still provide enough cooling perforamnce to not affect your overclock.
You can read more about my loop and the testing process here.
I'm interested in your thoughts and whether you feel this is consistent with your own findings.
- Quiet (pumps and fans both undervolted to ~ 7V)
- More Air Flow (pumps undervolted but fans running at full speed)
- More Water Flow (fans undervolted but pumps running at full speed)
- Noisy / High Performance (both fans and pumps running at full speed)
Conclusions:
