satanicoo said:Was this a single FX-74 against a single QX6700?
Or a dual FX-74 against a QX6700?
I mean, in the benchmarks i see them somewhat close, and if it is only a single, dual-core FX-74, wow...
Too bad the monstruous power consuption...
newls1 said:At least for 599 you get *2* FX72's
harpoon said:Sorry to have to link you to your OWN review Kyle... but it seems you need a bit of a refresher already! Long day huh?
Since these are the tests where C2Q soundly beats FX-74, and the rest of the benchmarks and applications are neck and neck, how hard can it be to declare a winner? I won't even include the gaming benchmarks because [H] doesn't take them seriously, and I respect that.
However, we can conclude that in 2/3 of the real world application tests, the differences between an FX-74 and QX6700 is negligible. But in the remaining 1/3, the QX6700 has a clear advantage.
The greater multitasking ability of C2Q ALONE should give it a decisive edge over the FX-74, as it's supposedly targeted at 'megataskers', and well, it's not 'megatasking' as well as C2Q!
Don't tell me it's hard to pick a winner here, because it's all damn clear for everyone to see.
The way you're trying to word things, it's as if an FX-74 is the equal of the QX6700. That clearly is NOT the case when we look at the entire picture.
If the answer is NO, how hard is it to declare a winner?chris.c said:So given that this AMD quad core solution is slower than Kentsfield in the majority of cases, consumes twice as much power, isn't really any cheaper, and doesn't overclock as well... why do you refuse to call a winner? Or at the very least make a more relevant, less vauge conclusion to your article. I don't care if AMD4x4 is the H2 of the computer world, and I don't need to be told it is "capable". I'm sure it is. I just want to know, bottom line, is there any point in getting this over Kentsfield?
mzs_biteme said:^^ Ditto on that....
Intel is the CLEAR winner here from many points of view...
Performance: Intel wins in most test. It would win in ALL by bigger margins if run at same clock (3GHz)
Power usage: Intel wins hands down
Overclocking: Intel's QX chips have been seen running at 3.4GHz+ (that's from 2.66GHz). With 90nm Quad FX you'll get maybe another 2~300MHz with Vapo and 1.5kW power supply...
As it is, the Quad FX to me is like Intel taking Pentium D's and sticking them in a dual-socket mobo... EVERYBODY would call it a "hack-job" and a ridicule it, yet AMD gets this:
"AMDs Quad FX platform is big, bad, expensive, piggish, powerful, and has an extended upgrade path that will allow power users double the desktop power in 2007. You could call the AMD Quad FX the HUMMER H2 of the computer world...."
I dunno....
saan44 said:I have to agree with the general consensus at this point. Given the price and power consumption of the 4x4 setup and the relatively small gains it has in the few benches it did win, the Intel solution seems like a far better option at this point.
If you are wanting to buy a quad-core machine now with no regards to upgrading to to an octo-core plaform later, you would be remiss to not invest in the Intel QX6700. The QX6700 is cheaper, uses less power, and will give you slightly better performance.
Which is sad if true. I don't think we've seen the last of AMD, not by a long shot. Either way though, competition is good for consumers. Even the most staunch of AMD or Intel !!!!!!s should have respect for the other company and the fact that the 1upsmanship between the two companies keeps prices (relatively) low for everyone and even if you hate AMD or Intel, lower prices are a good thing.Riddlinkidstoner said:Ridiculous. I guess the move onto Intel is finalizing.
Riddlinkidstoner said:After reading several reviews that have suddenly popped up, I can honestly say that AMD's 4x4 wasn't what I thought it was going to be. Intel definately has them by the balls here, I mean really...500 watts...without a video card? Throw me a damn bone AMD.
[H]ard is probably one of the only review sites that actually gave any credit to AMD, I just looked at Toms Hardware and they totally smacked AMD in the face with their 4x4 platform.
PunjabiPlaya said:edit2: AMD's solutions have always been very elegant and engineered with precision, while Intel has taken brute force methods (yes, even with c2d and the micro-ops). Just waiting on Vista/64 bit benchies. Will someone buy AMD another fab? Anyone?
phobos512 said:I don't think you're going to get anyone to believe that the QuadFX platform is anything other than a brute-force attempt to capitalize on multi-processor mania by AMD. I mean, come on, two individual dual core processors, essentially as the review said two motherboards on one PCB? What's elegant about that?
sxotty said:The truth is Intel and AMD are very frightened of the idea of enabling people to buy low end dual cores and make a quad core b/c it would kill the sales of their ridiculously overpriced chips.
Especially if it overclocks decently. One could even use a single core in each for an incredibly cheap dual core system. Anyway they are afraid of eroding margins and it is for good reason.
That is the only reason this is good, it might pressure intel to release a dual socket mobo for consumers at some point.
Hokum15 said:Kyle... Did you manage to get 4x 8800GTX's on it in SLI???
then you may see a defference in performance... in games at least... with quad Quadro 8800 eqv's it may also see better performace over the quad intel?
BFG have the factory water cooled single slot model...Ockie said:Umm this is not possible unless if you removed the heatsinks, watercooled it, and removed the slot brackets.
Then you'd still be limited to 8x pcie on two of the slots.
Hokum15 said:BFG have the factory water cooled single slot model...
