TheRapture
- May 31, 2000
My X4 965BE has found a new OC, 4000mhz (250x16) needing to really work it hard a bit, but so far it is holding up great after 4+ hours of F@H (4 instances).
Getting this with an actual 1.424v of input power, HT Link at 2500 and bus at 250. Gaming tests to come this evening. AMD says TCase Max is 62c, which seems to be ~5-6 degrees cooler than die temp. Coretemp is giving me readings of 61c-62c so TCase should be ~57c. The old Big Typhoon is really holding up well for a 5yr old cooler!
http://support.amd.com/us/Processor_TechDocs/43375.pdf cpu temp specs
I'll have to say, this little setup rocks just fine for 1080p gaming on my 37".
