Hi guys. My boss put together some parts for a PC. But we all saw he opted for a really underpowered 380W PSU.
Here are the core components for his rig. He'll be gaming. He's bought these parts and we just need a good PSU recommend for him that'll match the budget spent so far on everything else. He won't be overclocking.
Motherboard ASUS M4A87TD EVO AM3 AMD 870 SATA USB 3.0 $94
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131647
4GB (2x2GB) Corsair Value Select 1.5V $20ish
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145246
AMD X4 840 3.2GHZ x 4 95W $105
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103921
ASUS ENGTX460 DirectCU 675/1350 $165
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121391
DVD
SATA HD
Mid Tower Case
What do you recommend? I'm thinking he wants to keep it as budget as possible while still being safe enough to power his setup.
DVD
SATA HD
Mid Tower Case
