Okay, first new PC in a few years and I just want to make sure I'm balancing this out correctly. Using an existing Aerocool full tower case.
UPDATED SPECS BELOW...
I'm planning on some mild overclocking and I'm pretty sure that the BFT90 should work out fine. I wanted the Ultra120 but I'm not sure if it will fit in my case ( I still have to take some measurements). My biggest question, like many others, is the graphics card and display. From what I've read the GTS will handle 1680x1050 with no problems but 1920x1200 might be a bit much for it. At the moment I can't afford a GTX as the cheapest I've seen are about $100 more than the GTS plus the difference between a 22" and a 24" puts me over budget.
Other question is regarding overclocking. I've done it with my current P4 2.8 so I am familiar with what to do but I'm not sure about the RAM. Should I spend the extra money and get DDR2 1066 so the RAM is not a factor? Again, this would be a mild overclock, probably 400ish FSB, but I would like to go higher if I could without WC.
Any feedback would be helpful.
Thanks
Thanks
