I recently setup a new system with the following hardware:
TEMPORARY 8300GS AND 7800GTX
MSI Platinum SLI
Intel i7 920
6GB (3X2GB) Gskill DDR3
M-Audio 1010LT
Asus D2X
WD 300gb VelociRaptor
WD 1TB Green
WD 160GB Caviar
2 DVD-RW Drives
Thermaltake 850W Toughpower
All inside a Lian Li PC-101. Right now I'm using an old NEC 17 inch monitor at 1280X1024 but will be upgrading to some sort of a 1900X1200 display. Money isn't an issue but I would like to keep it under $500. Lastly, I'm not up to a dual GPU setup. This system is also used as a recording rig and PCI ports are limited. Should I jump on the 5000 series now with a 5870? Wait for the 300 series from Nvidia? Or wait for the AMD 6000 series?
MSI Platinum SLI
Intel i7 920
M-Audio 1010LT
Asus D2X
WD 1TB Green
WD 160GB Caviar
2 DVD-RW Drives
