williamjohansson
- Nov 17, 2004
im buying an aria chassi and i was wondering if anybody tried removing the cardreader.
and then take a pair of 40mm or 50 mm fans and attach on the inside?
i know there should be enough width for a pair of 50 mm... but would there be enough height?
i want to avoid cutting the the plates on the case if i can.
and i dont use a card reader anyways.
ill probably remove it even if i cant put fans i there. and put a dust filter on the inside or something.
btw. the whole system will be like this:
Antec Aria
Asus p5gd1-vm motherboard
Intel p4 3.0 ghz socket 775
Zalman ZM-7000B-ALCU
1024 mb pc3200 kingston value
Geforce 6600 256mb [not gt]
Maxtor 200 gb sata
Nec nd-3500a
Acer tft 17" AL1721hs
+ some small stuff
=should be about 1811$
Antec Aria
Maxtor 200 gb sata
Nec nd-3500a
+ some small stuff
