JustinSane
- Jun 29, 2005
Is the extra 30 bucks for the KUHLER worth it? Gonna be getting a 2600k and trying to hit 4.5 with it.
I won a Kuhler 920 here, and I was really excited to use it instead of my "old technology" Tuniq Tower 120 Extreme. In the end, I wound up switching back to the Tuniq. The Kuhler 920 is good, but it isn't that much better than high end CPU coolers. Like Kyle stated in his review, "silent" mode is very quiet, but its performance is abysmal. Extreme cools well, but is very, very, very loud. I found a similar "low" setting, but temperatures were 5C higher than my Tuniq under load and it was slightly louder to boot.
I haven't seen this mentioned in any reviews, but I found that the 920 took a very long time to return to "idle" temps. This was the typical scenario for my setup after a gaming session: the CPU would be idle, but the coolant temp in the loop is still warm (say, 40C). The coolant temp drops a bit (35C), so the software backs off the fans. As a result, the coolant temp stops dropping and stabilizes at 33-34C. The coolant temp before loading the CPU for a prolonged period was 28-30C, so 33-34C in the loop isn't "true" idle. This problem could've been solved with a more aggressive fan profile in the software, but that would mean listening to loud fans long after you had finished loading the CPU.
Further food for thought:
[H]'s results for the Kuhler 920
[H] testing results for Venemous X and Tuniq Propeller
Note that's with the same motherboard, same CPU, same overclock, and same room temps (25C)*. The extra $30 of the Kuhler gets you 2C worse performance under load, while overclocked, with the "low" settings**. The only reason I'd suggest the Kuhler 920 is if you have clearance issues or had limited room in your case.
*So you'd think they'd be on the same chart. There's nothing wrong with being able to compare lots of heatsinks at once, instead of having to dig through old reviews.
**The setting that people are most likely to use.
don't waste your time. install windows, get realtemp on there and see that your temps are probably closer 30 or less! trust me...i must've re-TIM'd 5 times before installing windows, and realized its the way the bios reads the temp.
