Ice Czar
Inscrutable
- Jul 8, 2001
I have an idea why not just PM AntecRep?
David thats coming awfully close to calling the OP a moron, by implication if not in fact
which of course would be against the rules.
personally Id check the connectors to verify that the pins are properly seated and then throw a multimeter onto it to get some real readings, then Id void the warranty and pop the top to see if the pot is glued, if someone forgot the spot of glue on the pot it could have easily drifted out of spec in shipping and a simple adjustment is all that is required.
(the pot adjustment not the resistor mod)
of course slitting that sticker voiding the warranty can be a stickler in most cases
sometimes its forgiven (especially if you can explain it and have personal connections)
alternately there is this stuff called solvent
That is of course just what Id do personally
I think you should start with AntecRep
davidhammock200 said:If I was Antec & some moron wanted to RMA based solely on BIOS/software readings, I won't grant it.
