Doing a "hold me over" upgrade on my old s-478 P4 3.0. Currently has the antec truepower:http://www.newegg.com/Product/Product.aspx?Item=N82E16817103928
and i also have the cooler master laying around http://www.newegg.com/Product/Product.aspx?Item=N82E16817171028&Tpk=coolermaster+460
Final build will be GIGABYTE GA-P31-S3G
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
E7200
HD4850
2 7200 RPM SATA drives
1x IDE dvd burner
So which power supply should i use? at first glance i would say the cooler master since it has 18A 12v x2 vs 17A and it has the 6pin plug for vid card but im not sure of the quality of one vs the other ?
E7200
HD4850
1x IDE dvd burner
