Hi,
I have H50 that I'm going to use but heard from many sources that pump makes ticking noise. I originally bought H50 and exchange for another one so I can confirm this. Then I came across thread in SPCR that some people used speedfan(I'm assuming you can do same with fan controller) to slow the pump which then they said it was dead quiet. Will there be any ill effect by not running the pump in full speed that it's supposed to run?
TIA
TIA
