This title is pretty much self explanatory here. I'm in the process of conceptualizing my first W/C setup, and I'm trying to figure out placement. I noticed many people have their radiator mounted at the top of the case. I was wondering if this causes a problem with air getting stuck at the top of the loop in the radiator? How do you properly bleed the system if the radiator is at the top of the loop? I have read that the reservoir or T-line has to be the highest point to properly bleed the system.
I am probably missing something very obvious because so many people have their radiators mounted to the top of their case.
Ross
Ross
