I would like to know if there is any SFF case that would fit a SLK-947u with a 92mm Vantec Tornado. I really want to get a SFF but I'm worried about cooling :O
I'd say most SFF systems come with their own proprietary cooling. Using a normal heatsink in a SFF environment would not be very efficent since it would just circulate the hot air around the HSF. That said, systems like the I.C.E. unit on the Shuttle systems are really efficent so CPU temps shouldn't be a problem. Other components like chipset, GPU and harddrives will run hotter than they would in a normal system, though.
