I updated my worklog regarding the final design of my reservoir, and as always I'd like to share it with you folk to get your opinion on it.
The image below shows the old design; the top item is the Collector, the bottom item the manifold.
The problem was for the original design I needed an acrylic block in the size of 100x100x200mm, and this proved expensive. So I redesigned the block to use cheaper, easier to get hold of sizes, and this is what I have come up with:
The price of all the parts (excluding fittings) is under £40 and a lot less wasted material. Made from two acrylic blocks, acrylic tubing, DD fill-port, threaded rod and 18 nuts. Add on the necessary hardware for connection and control of the circuit.
The ½ ball valve at the bottom is for the drain circuit, the 6 ¼ ball valves at the top are for the control of each loop. The DD fill-port is obviously there to fill and top up the circuit, and this can be done without opening the case. There are threaded holes at the top to mount it to the top of the case.
Just in case you don't know how it will be used:
Any thoughts? And yes, I am mad .
