Not at $45 a pop, pretty high $$ and you still need the cooler for the GPU...........
The big question for me is, do the power Mosfets really need cooling at all, knowing how HOT the reference cooler gets at that end of the card. Seems to me the Mosfets are better off having nothing opposed to baking under the reference cooler, however better to be safe!
The 45$ for the customs above is actually pretty good considering, however you can mount a $4 80mm fan pointed directly at them that will do the trick, and even run it on the 5V rail for lower noise close, or buy other sinks.
Most coolers like the Zalman come with ram sinks anyway so ram is a mute issue and is more than enough.
be nice to see some more official comments on this issue.
Easiest and cheapest way to cool them is to make a simple sink out of a old scrap Intel Pentium sink and use a little frag tape (thermal tape) to stick them in place, they will cool just as well as any other $45 option and won't cost you a thing, money well saver to pay for the GPU cooler its self................
Oh well, I guess some folks are just made out of money..........
Spend away my friends..............
These components that you all are wanting to cool do not get hot enough to warrant any type of direct bolt-on sinks and thermal paste, a standard stick-on type of sink is more than enough.
And, you've got to remember that the guys over at XS are known for doing things like buying pairs of $700+ video cards and then volt modding them.
Talk about voided warrenty
