Was looking at adding a pci-e video card to my new system build today, and ran into a problem.
The motherboard I'm using has onboard nvidea 8200 graphics, so I've had no problems using that up to now, but always had the idea that I'd like to have a dedicated graphics card. Today I tried fitting a card into the pci-e slot on the motherboard, only to find out that I couldn't attach a dvi cable or adaptor to the dvi output on the video card, due to the case construction!
Here's a picture that might make it clearer:
The motherboard I'm using has the dvi-e slot aligned with the top slot on the case. Unfortunately, that top slot doesn't have a lot of wiggle room, and once the card is seated, it pretty much sits in such a way that the dvi ports are too high in the slot to allow a cable or adaptor to be attached to it.
Short of banging away at it with a BFH (big f'n hammer), or cutting it with a dremel, does anyone have any ideas?? I'm thinking I might have to find a card that has an analog (15 pin, blue) port on it, just so it'll work with this case (and even then, there's no guarantee I wouldn't have the same problem!!).
Thanks in advance!
Thanks in advance!
