XG Duro ATX 2.2 4 x 12V Independent High Effeniciency
Features
* ATX 2.2 - 4 independent 12V rail
* Support Dual Cpu and Core
* Support ATX/BTX
* Active PFC
* High Effenicency
* 80mm Silent fan
* Stable and reliable.
* 4 X SATA
* Dual PCI Express
* Maximum Shielding
Detailed specifications
P4 Plug: Yes
Intel ATX 2.2
Fan Included: 1 x 80mm
Chassis Material: 1.0MM SECC Steel
Unit Dimensions: 200mm x 86mm x 190mm
Input Frequency Range: 50HZ-60HZ
Input Voltage: 110V~230V
Output: 850W, 900W peak
Supported for:
Intel Pentium 4
AMD Ahtlon 64/ Ahtlong 64FX
Misc. Features-
Supports Duel PCI-E grpahics cards, SLI or crossfire
Toughest EMI shielding protects your system and near-by appliances
Unique 4-pin Molex + SATA connectors in pairs give you a free choice on using either PATA or SATA devices
Full compliance with the highest standard to desktop power requirements; Split 12V rails provide most stable current to CPU, GPY, MB and drives
Specially designed 8cm fan combines silence and cooling by intelligent speed control
Quiet and Reliable
Convertible design to power up ATX/BTX systems and support dual CPU entry-level server/workstation
PF value up to 0.99 to provide stable and clean power under 100-24OVAC by auto switching
Protected by OCP, OVP, UVP, OLP, SCP, OTP for maximum safety. Full rated power under 0-40 o C/32-104 o F ambient temp
Nylon mesh binds the cables into a clean efficient cable management system while allowing maximum air flow throughout the chassis
Full support of Duel Core systems (incl. Pentium D EE and Ahtlon 64 x2) & Duel CPU systems
High efficiency of about 80% under wide load range (30%-100%) which minimizes your electricity bill
memphis_1220 said:I have never heard of the brand. But I would not trust it with a high spec system. Also, take a look at the spelling!
jonnyGURU said:I'm going to say that is probably a Seventeam unit since Wintech doesn't have any frames that can put out more than 600W. That said, I didn't know Seventeam was up to 800W. I thought they were only up to 700W. Of course, give a PSU company a year and they can figure out another 100W, right?
