anyone try this tubing?
never used it but from the features: "Excellent alternative to rigid piping systems "
i would imagine that this would be somewhat stiff and the bend radius wouldnt be that great.
Looking at the bend radii ratings in the PDF it looks pretty good with a bend radius of 1.75" for your particular tubing.
thanks for the input
from what i can tell it does seem stiff and surpisingly does have a tight bend radius, but id have to say it looks crystal clear compared to the previous tygon R1000 iv been using :D
Yeah, a 3.5" circle is pretty good and the tension should decrease against the bend as the tubing gains "memory" for being bent into that position. I'm interested to see how you like it later on down the road.
