http://www.aqua-computer-systeme.de...uct_info.php?cPath=7_177_178&products_id=1805
Can't read German worth a crap (can pick out a couple of words, that's about it) and Babelfish's attempt at translating it wasn't much better either, but here are some of the stuff I think I managed to pick out:
1) USB interface - no Aquaero required to change pump parameters
2) Max head pressure now 4.2m (Don't know if this is at the 72Hz setting or not, or if this pump even has a 72Hz setting )
3) Tach signal thingy to the mobo (like the DDC-2) so the PC can shut off when the pump goes *pop*
4) Temp sensor built into the pump (?)
5) There's no 3.5" bay panel thing anymore, the 12VDC-9VAC conversion circuit appears to be built into the pump.
6) In addition, there are three fan headers on the pump itself
I'm going to stop with my pathetic attempt to decypher the German now, I'll leave it up to you guys.
Definitely going to buy one when I get the chance though
