Oct 25, 2007 #1 P PornFlake Limp Gawd Joined Feb 24, 2005 Messages 270 I am getting ready to install the A7 into my CM690 case. My question is, If the fan on the A7 is pushing more air than the rear case fan can evacuate what issues might I run into? -Funk
Oct 26, 2007 #2 N nigerian_businessman [H]ard|Gawd Joined Sep 3, 2004 Messages 1,535 It won't, even if you turn off PWM and leave it run 100% all the time, which I do. I have the same case and the same HS. The HS is pretty restrictive and the fan doesn't have as much push as most 'normal' fans due to it being frameless.
