I was putting together a list for my next computer with a BFG 6600GT OC then it hit me. Since the BFG is the only 6600gt to have seperate ramsinks, will the NV silencer 6 (rev. 2) have problems fitting if I were to leave the ramsinks on?
why are you afriad to take the ramsinks off? if you dont wanna remove those, then check out the zalman flower gpu cooler. it comes with its own ramsinks, so you can just use the old bfg ones.
