In Q2 2008, Intel will push Penryn even further down the line and introduce a Wolfdale based E4xxx successor. This version of Wolfdale will have a 1066MHz FSB and drops support for Intel Virtualization Technology and TXT.
What about 975 chipsets? Will they unofficially support 1333mhz?
I think you're more likely to see a LGA775 1066MHz FSB QC Xeon Penryn than a Core 2 branded one. If there are any i'd guess it would be the lower end models.So there's the E4700 which will be dual core probably. Is there a quad core 1066MHZ penryn too?
So basically any 965 mobo has to be replaced in order to run Penryn's? (replacement would most likely be a P35 or X38)
I'm confused because on ASUS's website it says "Support Intel® next generation 45nm Multi-core CPU" even though my mobo (its in the sig.) is a 965 chipset.
heres a link :
http://ca.asus.com/products.aspx?l1=3&l2=11&l3=307&l4=0&model=1347&modelmenu=2
Will the 680i A1 from evga support penryn? I read somewhere that it will with a bios update. I want to hear it from here as this is the only place i trust.
Your mobo can handle 45nm, don't worry.
http://event.asus.com/mb/45nm/
Whether it would be able to overclock a 1333FSB Penryn a substantial amount is another story. To get a Q9450 to 3.6GHz would require a 450FSB, which is pretty though on the chipset.
Has anyone here overclocked a Q6600 on a P965 board? How are you guys faring?
Oh and a noobish question "if i have BIOS 1201 do i need to upgrade to 1501and then to 1601 or can i just go straight from 1201to 1601" ( i think i can go straight but just wanna confirm.
Now I'm confused... Does this mean the 945G/GC chipsets can handle Quads? I'm a HUGE fan of the 945G/GC chipsets, but to this date I've never seen Quad-core compatibility being advertised, not even on the "CPU support list"...Anandtech said:Elsewhere in the land of Intel chipsets, we have several manufacturers that will offer a combination of Wolfdale and/or Yorkfield compatibility on their 945GC-based motherboards. While this chipset does not specifically support 1333FSB operations, a couple of manufacturers have worked their BIOS magic to provide support
