Okay, so I have an Areca 1882IX-16.
I have a RAID5 array with 4x 3TB Seagate ST3000DM001 drives. This array has been running perfectly without any issues.
I purchased 4x 3TB WD Red drives. Popped those drives in setup another RAID5 array and was off. Then about 5 minutes into this, the Areca card froze. Don't ask me how, it just froze. It would no longer respond to any ArcHTTP commands.
After a reboot I get into the ArcHTTP and I was greeted with a WTF screen. My RAID5 Seagate array had failed (disk 1 and 2 were present, disk 3 was "missing" and disk 4 was assigned to the WD Red RAID5 array).
THE PROBLEM: The card was using disk 4 of the Seagate array to rebuild the WD Red RAID5 array. SO really, WTF. This is bullshit.
I have been back and forth with Areca support. The card recently had the stock ram stick crap out on me. I replaced it and it has been working fine. However, now the card will not boot up at all if any drives are attached. Repeat, the only way the card will boot up is if no drives are attached. I know the drives are not the issue because they have been working fine. Needless to say this card is pissing me off and the fact that I may have lost some of my data due to the inability of the card to be reliable is just icing on the cake.
No real important data, I have most of it backed up. That is not the point. Areca charges a crap ton of money for these cards. They should be much more reliable.
